Thread: MAFT questions?
Old 08-09-2011, 12:18 PM   #1
El Supracabras
El Supracabras's Avatar
You need MAFT PRO to run in speed density. It is not a function of a regular translator which will only allow the use of a larger GM MAF sensor instead of the KVAFM. It also allows you to run in "blow through" configuration which means you can vent your BOV without stalling.
CRE used to have a bunch of info in his sig about it. Hopefully he will have something better to add.
