Old 08-08-2011, 04:51 AM   #31
turbonicsperformance
turbonicsperformance is on a distinguished road
yeah i put in some spades so i can just plug in the fumper to check my timing but as far as codes go im not concerned with it i only have injectors, tps, cps, kvafm, oil psi, coolant, and 02 hooked up so i'll always have like 10 codes stored
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
