Old 08-05-2011, 06:06 PM   #1
MA70-3.0GT
MA70-3.0GT's Avatar
Wow seems you're right on that, and then I'd still need the impeller as well on top of all that & importing it...
Just thought it was worth a check as I don't like waste & the housings and core casting are fine. Am now on the hunt for a decent used CT26 in the UK then I guess... (or even one that smokes/bearing shot as long as the shaft, turbine & impeller are in good nick, if it's cheap enough since that rebuild kit would work out then)
