Old 07-30-2011, 02:31 AM   #2
El Supracabras
El Supracabras's Avatar
If you think you are losing pressure, look up the correct specs and install a mechanical oil pressure gauge and check it to make sure it's not a gauge issue.
If it is a gte block, the engine uses a low pressure oil system. I think at idle oil pressure is only around 5psi when hot.
