Old 07-29-2011, 01:01 AM   #1
907mge
907mge's Avatar
Advance auto has a loaner tool program where you should be able to borrow a spring compressor for free. It is a rather simple device and if you have stock struts and springs they are not under too much pressure like some cars. But still use caution since it is a spring used to hold up a 3600lbs car. And as far as a jack goes the factory carry along one will do since you should not need to be under the car to replace the rear struts. And a jack stand is not a bad idea.
