Old 07-28-2011, 08:02 PM   #1
El Supracabras
El Supracabras's Avatar
I run braided stainless hoses from the tank to the engine and back. It's alot of money and not really necessary unless you're doing a big build. I would suggest sinking the money other areas of the car unless the fuel lines are in need of attention (mine were rusty ,so i kinda went nuts). I used a mix of Aeroquip, Earls and DM pieces. They all were of good quality and I would recommend any of them. I had to make the lines from the tank to the engine but Drift Motion sells the FPR hose kit, damper bypass hose and CSI braided hose. The adapters are no problem as long as you know which ones you need, you can order them from many vendors.
