Old 07-27-2011, 05:23 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by chuck View Post
which motor will make around 480 hp the cheapest? id like it to be N/A but if that will cost alot more than a single or twin turbo set up ill go turbo. suggestions?
If you're talking 480hp to the crank, then a stock 2jz-gte with stock turbos can make that power level (BPU+++, raised boost, race fuel). I believe this will be cheaper than trying to get that much power out of an n/a, which will require an aftermarket turbo kit or a huge shot of nos.
Life begins at 30psi.
