Old 07-27-2011, 12:19 PM   #1
El Supracabras
El Supracabras's Avatar
If nothing is working at all, and you are 100% sure the battery is charged and the connections are clean and tight, check the 8 gauge wire that goes from the battery positive terminal to the fusebox behind the battery. That is the wire that feeds everything but the starter. Check the main fuse inside that box as well.
