Old 07-26-2011, 05:55 AM   #1
Mk3FirstCar-Mike
Mk3FirstCar-Mike is on a distinguished road
Check the ignition timing, make sure the injectors aren't clogged, the fuel pump and the throttle body bore, as-well-as the air filter, fuel filter, EGR system and if you absolutely HAVE to.. a compression test. Those are all of the reasons I could think of that may cause this problem.
-More than likely the fuel filter.
Last edited by Mk3FirstCar-Mike; 07-26-2011 at 05:57 AM. Reason: Forgot the (most likely) area of my post.
Mk3FirstCar-Mike is offline   Reply With Quote
