Old 07-25-2011, 04:47 PM   #1
El Supracabras
El Supracabras's Avatar
http://cgi.ebay.com/ebaymotors/89-92...item27bbd268a4
This looks like a newer version of the one I bought 2 years ago. I bought directly from cxracings ebay store. I have had zero problems other than the piping for the pcv and vac lines don't line up with the bolt holes on the crossover pipe (3000 pipe replacement) and the intercooler itself is much heavier than the stock one. It also is NOT a direct bolt at all. I had to relocate my oil cooler, horns, coolant reservoir, steering cooler, make brackets (which I think are now included) and modify the hood latch support a little so it would clear the front crash bar.
Good luck, and don't you think it's time you put some pics of the beast up?
