Old 07-24-2011, 08:56 PM   #3
1991 supra guy
1991 supra guy is on a distinguished road
Default ac belt
Thanks loosening the bolt going through the pulley was the trick. It allowed the tensioner to drop releasing tension on the belt. After removing the belt the clutch does not rotate and the pulley will but just a little it seems almost frozen. How likely is it that the compressor is rebuildable? Have any of you had it done? Is it more cost effective to buy a new remanuf one?Thanks again for the tip.
ID:	4087   Click image for larger version
1991 supra guy is offline   Reply With Quote
