Thread: Headlight
Old 07-22-2011, 06:00 PM   #2
El Supracabras
El Supracabras's Avatar
After physically checking, I have a left side assembly from an 89. I also have a right side assembly from an 87 and they use different plugs. You may want to check if they are interchangeable between the years, if they are you can just cut the plug off your old motor and splice it onto the one I have. If you're into that sort of thing.
