Old 07-22-2011, 12:07 AM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by 792 View Post
The reason I'm swapping a JDM engine in is because I'm on a budget and found it to be cheaper if i buy a cheaper N/A supra with the 2jzge, import that, and then do a swap to a very low mileage 2jzgte. Could I expect it to be cheaper if I just do a twin turbo conversion on the 2jzge instead of doing a swap?
Yes, if you want to end up with the performance of a full TT. The TT model is MUCH, MUCH more than an n/a with a couple of turbos. Please see the bazillion threads on this forum where I describe all of the differences.
And yeah, i realize that Labor will be alot of the cost. I don't want to do anything im unsure about and potentially ruin components of the car which is why I will probably do most of it in a shop.
So if $7k is your budget, and if you want to drag race and roadrace too, and you're going to pay for the labor, AND you're starting out with an n/a (!!!), then I have to revise my earlier estimate. When you said an Mkiv with a 2jz-gte, I thought you were buying a TT. With that budget and an n/a, you'll be lucky to get 325rwhp. Don't forget that you'll need a whole new harness, ignition system, ignitor, resistor pack, etc., etc. to swap in that 2jz-gte. The best bet is to not buy an n/a and save up for a TT.
Thanks for answering by the way. I've read alot of other questions youve answered for other members, too. Most recently about the South Bend Kevlar clutch and Cyn-R-G flywheel I believe.
Glad to help. Please keep your questions coming!
Life begins at 30psi.
