Old 07-20-2011, 09:07 PM   #2
792
792 is on a distinguished road
Labor can be a big part of the cost. If you're not very experienced with the Mkiv Supra Turbo, you shouldn't attempt the work yourself without months of reading tech articles and forums, and then having the TSRMs by your side. That $7K works out differently if you have to pay an Mkiv TT experienced mechanic to do the work, or the $7K is parts-only.
Why swap in a jdm engine? Sure, the mileage might be lower, but the hours on the engine will probably be higher. Time spent idling (and revving) on the constantly-jammed streets of Tokyo is a big factor.
Just offhand though, if you're going to both roadrace and drag race it, you're probably looking at a bpu+++ Mkiv at best for that max amount...which means about 425rwhp at best, reliably. Imho, there's no way you get a fuel system and an aftermarket turbo system on the car for that price, and then still have the $ you need for clutch, rims&tires, race fuel, and all of the other odds-and-ends you'll need for roadracing and drag racing.
The reason I'm swapping a JDM engine in is because I'm on a budget and found it to be cheaper if i buy a cheaper N/A supra with the 2jzge, import that, and then do a swap to a very low mileage 2jzgte. Could I expect it to be cheaper if I just do a twin turbo conversion on the 2jzge instead of doing a swap?
And yeah, i realize that Labor will be alot of the cost. I don't want to do anything im unsure about and potentially ruin components of the car which is why I will probably do most of it in a shop.
Thanks for answering by the way. I've read alot of other questions youve answered for other members, too. Most recently about the South Bend Kevlar clutch and Cyn-R-G flywheel I believe.
792 is offline   Reply With Quote
