Thread: Ignition
Old 10-04-2005, 09:09 PM   #2
rnoswal
rnoswal's Avatar
Well then go with the expert and try what Suppra_girl suggested. Sounds like you did the obvious stuff. Make sure of your grounds, they are every where, make sure that battery is not being drained while just sitting there. If you don't want to go the route of the ignition switch, the go the remote starter button, that will eliminate all the wiring that might be bad, but I would at least try a new switch,
Russ
