Thread: MAF Replacement
Old 07-14-2011, 01:31 AM   #1
Green7mgte
Supra Forum Moderator
you can hook up the black box. just not the honey comb w/o any ill effects.
code 31.. before you spend any money do yourself a favor and run an ohm meter from your pins and check the wires.. if you have a bad wire, replace it. Otherwise spending w/e money you did on your KVAFM is money wasted.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
