Old 07-08-2011, 03:36 AM   #1
87supra7mgte
Default very simple check
is the wire that goes from the harness between the head/intake hooked up? should be a black wire with a blue stripe, plugs into a hard to see spot on the starter, its the switch wire for the starter to engage, if it is just start working your way back, relay, clutch depression switch, ignition switch, checking all grounds along the way, had this same problem after i replaced a BHG and it was simply the wire
