Old 06-17-2011, 03:39 AM   #1
supraturbo_mk3
supraturbo_mk3 is on a distinguished road
The characteristics of failure from oil coking (from not letting a turbo cool a bit before stopping the oil flow) and from compressor surge are very different.... if you have a mind to do an autopsy. If he wanted to know what killed it your friend could have found out.
I'm glad everyone knows what it is and why it sounds that way... The only way you're going to get that sound without the oscillating manifold pressure and erratic valve behavior would be to add more piping with a mechanism to create the effect (I'm thinking copper pipe and ball bearings, reliefs cut in the pipe above the ball bearing's resting point).
Keep in mind that at low pressures (where it's more likely to occur) isn't always going to cause a problem, it depends a lot on the rest of the system and the health and design of the turbo. The reason you hear a lot of highly tuned cars make that sound it that the BOV is intentionally tuned that way. This allows for a slight increase in responsiveness while shifting but once the system starts bossting past what they consider to be a critical level it will open properly and the flutter sound will stop. Some people do it just for cool points though. A lot of high end race cars employ multiple BOV's each set at a different flow and trigger pressure. A small BOV used at lower boost levels to bleed just enough to reduce surge but leave enough pressure for a quicker return to positive pressure after the shift, then another large unit to dump at higher pressures. I know, an even quieter solution isn't what you're looking for... sorry.
I see what your saying....When driving my normal, (low boost) my old 95 GS-T would flutter a little (not very loud) but at high boost my greddy type S would sound normal but my supra doesn't do that at all and I miss it lol
IF IT AINT A SUPRA IT AINT SH*T!!
87 Supra N/A JDM 7MGTE, 8psi, 2.5inch Exhaust, 18inch Rim's, 255/45/18 rear, 255/40/18 front, 3inch DP, Ported 3inch elbow, Stage 2 6 puck Clutch
95 Eclipse GST 15psi, 3inch Stainless Steel Exhaust, 3inch DP, MBC, 2.5inch Upper I/C piping, Short Throw Shifter, Stainless Steel turbo inlet, Type S BOV (Sold)
89 Supra Turbo, 12psi, 3inch Exhaust, Ebay intake, 2.5inch Upper I/C piping, ARP Head Studs, Stainless Turbo Manifold Tial BOV (Sold)
(Sold)
supraturbo_mk3 is offline   Reply With Quote
