Thread: NEEd HELp
Old 06-11-2011, 02:14 PM   #33
El Supracabras
El Supracabras's Avatar
Test that cap again, new doesn't mean good. Make sure it can hold the correct pressure. If you think you have radiator blockage, you might find it using an I/R thermometer. Is the radiator in good shape (fins, tubes damaged or rotted)? Is everything else in good condition? (water pump, ALL hoses, fan/clutch/shroud, correct t-stat). Test the coolant for hydrocarbon traces if you think the block or HG is at fault.
