Old 06-11-2011, 08:47 AM   #2
87hilux7mge
87hilux7mge's Avatar
as i recall, the front sump 7m pan only came from the cressida. if you post pics of what pans you have i could give you a better prognosis.
if they are both front sump then is should bolt on no problem, oil pump match and all. if yours was originally a mid sump, and you have a front sump pan, then youll have to swap a front sump oil pump in. vice versa for the other other way around.
