Old 06-11-2011, 06:19 AM   #2
Semper_Fi
Semper_Fi's Avatar
Semper_Fi is on a distinguished road
Originally Posted by 87hilux7mge View Post
my guess would be improper cam timing. the valves are probably open during compression strokes.
did you make sure to use a proper compression tester? those "hold in" ones arent worth a damn. a screw in type with o-ring gaskets works great and are only about 15-20 bux.
another option is improper tq specs on the head bolts, left a gap somewhere maybe?
Yeah i checked it with a renter from autozone... i believe the last three were getting some kind of compression, but after checking the first 2. i jumped to the conclusion that i installed the piston rings wrong. So i ripped it apart.. were do i start?? thanks for the support everyone.
Thanks again. Carlos
1989 supra turbo-
uh-60 blackhawk... My life
Semper_Fi is offline   Reply With Quote
