Old 10-04-2005, 03:34 AM   #1
mrnickleye
mrnickleye's Avatar
Keep an eye on your overflow coolant bottle. If you start having to ad coolant to it, you got a BHG most likely. Worn valve guide seals will allow oil to seep into the engine combustion chamber as it cools down. When you start up, it will burn off the oil, and after it is up to normal temp, it quits smoking. A lot of work to replace seals.
