Old 06-04-2011, 06:51 PM   #1
suprabahamut
There's noting wrong with filling it through the top.. Naturally it's foolish if you don't have a way to check that you are at the right level but sometimes it's still easier to fill this way even if you can get the fill plug off to check the fluid level.
Yeah I usually fill from the bottom and make the level right. But since the transmission is leaking it is the rear seal I am going to fix it soon. I usually put a little more in for the long run.
