Old 06-03-2011, 10:42 PM   #1
El Supracabras
El Supracabras's Avatar
Actually after thinking about it (i dont know why I did) it may not be the turbo at all especially if you say it's tight. If it only does it in gear and not at all while stationary, what does that say? Trans? Is the fluid low? Burnt? Differential? Is the fluid full? Two very easy things to check just go to lube shop or something. I tip the guys by me a 5 and they check and fill everything on all my cars, even the coolant. They should really pay the techs better, they'll give me anything in the store for a couple bucks on the side. I've never even got an oil change there. Anyway it's something else for you to check out.
