Old 06-03-2011, 06:30 AM   #1
87hilux7mge
87hilux7mge's Avatar
the pistons and rods will be a good upgrade, def get the rotating assembly balanced professionally, itll smoothe it out and rev a bit easier/more too.
check the cyl head out and see what needs replaced ( guides, seats ground etc.) then do a small diy pnp. a set of stock valves will be fine, spring upgrade (if there is one for the 5m?) headers help alot, you wont see it on a dyno necessarily, but it makes for good drivability.
i think you mean a 255 lph fuel pump. and swapping in a set of cleaned 7m injectors would be more than enough, they spec out at about 310cc i believe.
what are you gonna use for EMS? stock or aftermarket?
sounds like a solid plan, should be good.
