Old 06-01-2011, 04:33 PM   #11
916MKIIIx2
916MKIIIx2 is on a distinguished road
Ok, So I put in the fuel filter and it helped, but did not fix the rough idle on start up. So I pulled out all the spark plug wires again took them up to wyotech and tested them, all came back good, tested all my spark plugs also came back good at both places I tested them. So I said fuck it, since I had one extra spark plug, started with replacing cylinder #1 spark plug, still rough idled, then moved the good plug to cylinder #6, rough idle went away but now I can really feel the miss fire, I almost want to say its inconsistently missing 2 cylinders... Coil pack? If I remember correctly the coil packs are 1 per 2 cylinders, get back to me please, the problems almost fixed!
916MKIIIx2 is offline   Reply With Quote
