Old 05-31-2011, 12:28 PM   #1
Green7mgte
Supra Forum Moderator
no, the turbo does not kick in while the car is in neutral.
My first suggestion / question.. Is to see if the car gave off any cells.. Did your check engine light come on? if so you have a stored code that you should read.. Do A diagnostic and see what your engine is telling you.. Heck check your tranny dio also. Doesn't sound like a transmission problem tho, sounds like an air problem. Theres a "how to" check your diagnostic here in the mk3 faq..
good luck, report your finding.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
