i just noticed something on my clutch master and thinking to myself maybe this is why my clutch is being weird...
the over-center spring is used to help the clutch pedal pop back when its over center..
so i push the clutch in. it comes back from the pressure in the master cylinder.. but the over center spring as no effect with the pedal.. i heard its spose to back the pedal back to its original place(which my pedal is not)
so i was adjusting awhile and made it so that the pedal stayed dead center when i pulled it back(to where its spose to be) i added a spring the help it get there(barely worked) and still not getting it back enough...
my question is this. (i cant adjust it to be over center becuz its already at the end of the push rod.) would i need a longer push rod or clevise to be able to adjust over center, so it will pop back all the way?
or is there anything i can do that will help my clutch return and have a better more fuller dis-engage. (it dis-engages but shifting is ruff, like it isnt a full disengage, but it is O.o lol its hard to explain)
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
