Old 05-30-2011, 12:40 PM   #1
El Supracabras
El Supracabras's Avatar
If you have already checked what cre has recommended, and they check out ok, you may have a problem with corrosion in the rear of the car. Water gets in the hatch and tail light housings and corrodes the wiring, bulbs, sockets, sheet metal grounds, lamp failure module etc. Give it all a good look over, if you have a multi-meter or test lamp to use you should be able find where the voltage stops.
