For everybody who run's the 1/4 mile
I think most of you will like this setup....I'm betting that could minus a full second possibly more off of my E.T.....I don't trailer my car so this would be great. Just posting this in case other people are looking for drag radials.
Here is the site info on them....I do have the link to the site but I'm not sure if I can post it.
This is the combination drag wheel and tire set-up that is being run by ALL the top Supra performers. Not as light as the rear Bogarts, but these can be street driven.
These custom 16x4 front and 16x10" rear CCW mesh drag racing wheels are custom built and designed for the Supra. This is what it takes to get great launches and when coupled with our 16x4 front skinny set-up, your car will track straight and true in the 1/4 mile.
This is a complete set-up with wheels, tires, mounted and balanced. Skinny 5" Fronts are mounted on the front CCW wheels (requires 1/3" spacer, not included) and Mickey Thompson ET Streets (no spacer required) are mounted and balanced on the rear. No center caps are available for the 16" Supra drag wheels, as per CCW.
Complete set-up for going fast in the 1/4 mile!!
IF IT AINT A SUPRA IT AINT SH*T!!
87 Supra N/A JDM 7MGTE, 8psi, 2.5inch Exhaust, 18inch Rim's, 255/45/18 rear, 255/40/18 front, 3inch DP, Ported 3inch elbow, Stage 2 6 puck Clutch
95 Eclipse GST 15psi, 3inch Stainless Steel Exhaust, 3inch DP, MBC, 2.5inch Upper I/C piping, Short Throw Shifter, Stainless Steel turbo inlet, Type S BOV (Sold)
89 Supra Turbo, 12psi, 3inch Exhaust, Ebay intake, 2.5inch Upper I/C piping, ARP Head Studs, Stainless Turbo Manifold Tial BOV (Sold)
(Sold)
