Thread: ecu troubles?
Old 05-26-2011, 01:47 PM   #2
El Supracabras
El Supracabras's Avatar
You know that little bunched up set of grounds that goes under the intake manifold right by the brake booster? Check those again. Make sure they're perfect. It would be best to check the continuity of the ecu ground if you can too. If the car wont run, somethings missing. Do the basic checks (spark, fuel,etc). Was the harness an exact replacement?
