Old 05-15-2011, 02:20 PM   #13
Spartacus
Spartacus is on a distinguished road
Originally Posted by spunkenhimer View Post
there are a lot of factors that we may need to know about your car here. If its turbo then you may want to have that checked for cracks or leaks. also if its reg 7mge then could be a bhg or timing slip i'd check the timing if you can get a timing light on it. also i've heard that the 7mge gas pumps go out pretty easily sometimes.
if you can do a diagnostic check on the car this may help
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/
the diagnostic specs are in there somewhere.
Thanks for your reply
The car is not turbo. I just had and engine tune-up last week so I dont think its a bhg or timing, I like the mechanic, I assume he would check those things.
Could be the gas pump, do you know how I could check for that?
The diagnostic isnt throwing any codes
Spartacus is offline   Reply With Quote
