Old 05-12-2011, 07:20 AM   #3
Cyberguy1992
Cyberguy1992's Avatar
Cyberguy1992 is on a distinguished road
just make sure your ignition timing is set correctly.. Also check if you have oil around the spark plugs if you do then u probably need to replace your valve stem seals... Its not hard just time consuming and a bit tedious..
Cyberguy1992 is offline   Reply With Quote
