Old 05-06-2011, 09:27 AM   #22
ochowdero
Originally Posted by 87hilux7mge View Post
ok. i hate to be mean, but you need to stop driving your car with just base knowledge slammed at it. the seal you have in your pics is prolly a rear tranny seal, and from the sound of it youve been puking fluid out of it. you obviously overfilled it, and thats where all the leaks have been coming from..
just slow down and stop jumping the gun. you need to give us all more info on whats goin on than what youve been doing, cuz were only getting half the story.
so, u over filled..what else. just take it slow and explain whats happening.
i put transmission fluid in.
tried bleeding it and didnt work..
then tried a "Bench bleed" on my master cylinder and it worked alil just gotta adjust it and get it perfectly bled..i did that so i can shift to get it to my shop(a mile up the street)
tomorrow regardless, im taking it to the shop to have my mechanic properly bleed my system...
like i just said when i pulled back my carpet i was able to used the clutch properly because it fully disengaged, SO I NEED TO ADJUST IT, SO ITS LIKE ITS SPOSE TO BE.
so back to the tranny, i put 3 quarts in, i know that is an over fill... so that goes to why im leaking...
i need to know if that "seal" is needed in my trans and if i can drive without it, to get my clutch bled properly..or even drive without it or what the heck it is and for. i dont mind going back under the car and replacing it but i need to know what it is, and if its needed or not.
and like i said, it only leaks after driving it..
idk why(besides overfill)
" i hate to be mean, but you need to stop driving your car with just base knowledge slammed at it"
what do you meen by that?
1987 supra, BLUE 7mge.. AUTO TO MANUAL SWAP..
i really want turbo
