to those of you that helped
thank you. finally got it running. Was the simplest thing to do.
I went thru the tsrm list of possibilities, starter/ leads/battery/ relay and it was on the final one that i hit on it.
Was the nuetral switch. And even then the switch wasn't faulty.
I was about to pull it till i saw how buried it ws behind the exhaust, so i thought first i would clean the connections............. a shot of gunk, folled by a shot of brake cleaner and a liberal shot of elec contact cleaner. wipe it down. then when tried to start, it started when i held the key and went thru the shifter. Kicked over on my way back into nuetral. Has been good since.
I assume the connections were corroded.
thks again.
