Is this your first turbo car?
stock turbos?
Any aftermarket ecm or piggy back?
You won't hit 400 without upgraded turbo or turbos can't rum over 14psi on stock twins due to the ceramic wheels literally blowing apart.. Plus fuel mods. The stock 370cc injectors are good to at absolute max 375hp with aftermarket ecm. On piggy back I'd say 325, You can upgrade those to usdm 2jz 550cc thou.
And the stock clutch is only good till 350 wheel HP. Give or take depending on tune cuz torque decides when ur clutch slips!
And I hope you kno you can't dyno tune a car without an upgraded aftermarket ecm or a piggy. Back system. Which if u use piggy back your capacitors in your ecu need to be changed asap.
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
