Old 04-27-2011, 08:19 PM   #1
Green7mgte
Supra Forum Moderator
Originally Posted by 87hilux7mge View Post
boost leak somewhere? maybe cre can shed some light. have you searched yet?
my asshole is itchy.. cre can you hold this flash light and shine it. tell me if I have a hemorrhoid.
damn that shit pisses me off. Hey how about we just rename the forum to CRE please answer my questions.. obviously no one else here is able to..
could be acouple things. you said you were or werent throwing any codes? give it a check. make sure all your spark plug wires are secured. (snug) and I would check you're fuel pressure.
if your checking for boost leaks the most common areas are the Charge pipe right off the bottom of the turbo and the couplers at the 3000 pipe..
You said you just bought this car.. Did the previous owner do anything to the waste-gate to throw more then stock boost? allot of boost and not enough fuel will bog your engine down, running lean does the same.
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
