Old 04-23-2011, 03:22 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by kawboyz2002 View Post
Hi, I'm fairly new to the supra forum. I bought a 1994 N/A about 6 months ago. I've always wanted a supra and now that I've finally got one, I plan on making it look as nice as possible. I found a set of wheels on the Internet that will look sweet on the car... The fronts are 20x9 +30 and the rears are 20x11 +38... my question is, will these wheels fit without any rubbing issues... Also my car is at stock height...
Oh yeah, and what size tires should I run on them.
They may not fit perfectly. I believe the oem offsets are +50.
On an n/a, traction isn't an issue. However, with that large of a diameter (20"), you'll want a very narrow sidewall on the rear to reduce the inaccuracy of your speedometer. The narrow sidewall will also help reduce rubbing issues.
Life begins at 30psi.
