okay, i did have that in mind and a helpful mechanic that i know dropped by and help test things........ as a point of curiousity he asked if i had an alarm system........... well i do, aftermarket, and what is happening is exactly what it did before when i sat inside and armed it. problem is it won't disarm. How it got armed i do not know. The car is in a spot where there is no need for me to use it, so i just never thought about it.
the alarm i believe is overiding the start function, so no matter how many wires i pull and clean it will be the same. Well gonna drop down where i had it installed and see if they can tell me how to override so i can at least eliminate it. keep u posted, least that way if it is the problem some other poor smuck won't go what i went thru.
