Old 04-22-2011, 08:27 PM   #1
Stock dish is 3mm below the crown. I don't know what's up if you've actually got different pistons; Usually the high readings are the result of oil draining into the cylinders from the plug galley.
Danny, what's your timing set to? Retarded timing (both mechanical and ignition) will cause higher engine temps.
