Old 04-22-2011, 06:02 PM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Sounds like it could be something as simple as a discharged battery, the positive or negative terminals are not connected securely on the battery, possibly a bad positive wire running down to the starter (the large diameter one).
An easy test for the first two would be to use another vehicle, hook them up with jumper cables (large diameter, something around the 4ga size), and then try to start it
