Old 04-21-2011, 12:28 PM   #1
Travis89Turbo
Travis89Turbo's Avatar
Ok here we go..... the speedo cable I have never had trouble hooking up and workin. All though they are technically different lengths.
They neutral switch some will recommends pulling the actual switch out and locking it in park. Myself I always Jus cut the switch wires ( don't quote me but I'm almost positive they are black with white and black with blue) I Jus cut and splice the two together so I don't have to hide that big switch. Never had any problems.
The starer really only goes in one way! Don't forget to hook up the little signal wore on top of starter.
The bolts you showed look to be proper length and size. The starer takes a lot of torque to turn the motor over.
and the gold washers I haven seen myself. but I would guess they are being used like you said on the driveline carrier bearing!
hope this helps!
stock 2jzge
1999 Ford F350 diesel
2004 Jaguar XJR Supercharged
