Thread: speedo problem
Old 04-16-2011, 09:45 AM   #1
87hilux7mge
87hilux7mge's Avatar
had alot of sbc's, including my old maro with a 375 hp 360 cubic incher with a wct5 and 3.73 posi. one in a supra would be fun with all the low end torque, move the heavy chassis alot easier from a stop.
neway, you will prolly have to get aftermarket gauges and use the stock th350 cable. or see if you can find the toyota speedo gear sizes (contact dealerships) and then find corresponding chevy ones to match. that would be alot of work and research, for possible wrong end results. a full set of autometer gauges is only about 200 bux, and you could calibrate them to whatever application you have, usually.
