Old 04-15-2011, 11:31 PM   #2
dannydavi
dannydavi's Avatar
Originally Posted by btwilson86 View Post
After it overheats, is there any hot or cold spots in the cooling system? For example, is the upper hose hotter than the lower hose? One side of the radiator hotter than the other?
A possibility is that there may be some sort of blockage restricting the flow of coolant, causing it to overheat
I will hand check multiple places next time it occurs, I don't have a temp gauge that I can use to test it. Also I will try to see if the rad is blocked up at all... Any good ways to test that? I will try taking both hoses off of rad and full pressure garden hosing in the top and see if it backs up at all...
'86.5 Supra - A/T - N/A - JDM
Useful Sites:
ToyoDIY.com
ToyotaPart.com
MKIIITSRM
