Old 04-15-2011, 07:52 PM   #1
interested!
Hi!
The problem is not the cam cover gaskets although they may be loose too-- but leaking cylinder head oil gallery plug o-rings - these are in-line with the plugs on the 7MGTE engine, they have hardened to carbon state and have probably cracked causing the plug hole(s) to fill from the outside.remove the plugs that leak,change the o-rings and that should clear the problem --did on mine!!!
