Old 04-15-2011, 06:25 PM   #1
interested!
Default starting issue
Hi!
Had exacly the same problem after MY cylinder head overhaul --engine cranks but will not fire up at-all . my solution : I found a whole bunch of wires UNDER the inlet manifold that should be connected to earth -mine wern't ( forgot they were there! ) -so I did -and then my car started, are yours intermittently connected? ( dry joint/loose bolt/broken wire connector ?) you will need a good mirror and torch -they are to the rear of the manifold under the throttle cable side.
