Thread: speedo problem
Old 04-15-2011, 02:57 PM   #1
turbonicsperformance
turbonicsperformance is on a distinguished road
one way to find out is to take a drill and spin it at max rpm on this speedo and then do the same with a chevy speedo and see if they show the same reading if not then your gonna need a chevy speedo/ aftermarket
but the supra speedo/speeo cable are pretty notorious to for lack of a better word suck, so you may stray from usng them
you also have to consider your gearing though
92 miata 7mgte swap forged pistons,studded mhg, 3 inch dp with a glass pack,blowthrough MAF-T,550cc inj, act stage 2 clutch, fmic kit, greddy rs, full wire tuck, rx7 lsd rear with 4.10s. 15psi "ct26-A"??(waiting on dyno #s) if anyone knows whats up with my turbo let me know it has a larger comp wheel nicer machining and 6 dual fins rather than 5? its confusing and keep finding too much contradicting info. would LLLLLOOOOOOOOVVVVVVVEEEEE a compressor map
turbonicsperformance is offline   Reply With Quote
