Old 04-12-2011, 01:50 AM   #1
gaitski
gaitski is on a distinguished road
Throttle cable seems alright, it's not hanging loose or anything. Is there something in particular to check there?
I disconnected the battery and pulled the ECU out to take a look at it and reset it. When I put it all back together, no codes, but now it isn't starting at all. It cranks fine, but nothing after that.
I'd like to test the ECU, but I'm kind of confused by the Cygnus site. Do I pull the ECU totally out and use a multimeter on it then, or am I testing the plug ends that plug into the ECU?
Thanks!
gaitski is offline   Reply With Quote
