Old 04-06-2011, 03:48 AM   #1
Green7mgte
Supra Forum Moderator
Originally Posted by free_couch View Post
the valves in cylinders 3, 5 and 6 have heavy oil/carbon deposits. I also noticed that the spark plugs from these cylinders were covered in oil as well. I know my engine had been burning a little oil on startup, good cylinder compression: cylinders 1-6: 170,170,182,175,180,180. (note the higher compression on the cylinders that have heavy oil/carbon deposits)
tsrm says you can expect a varation of up to 14psi between cylinders. (please correct me if im wrong)
valve guides usually present themselves with smoke on startup / deceleration
Hows your #3 valve cover gasket.
Its hard for me to give you a definite answer, I really never fiddled with my valves first hand.
with your car at idle can you see bubbles oozing out around your spark plugs?
92 Ma71 7mGTE Auto. SafcII
Supra FAQ
Supra MKIII FAQ
