Old 04-02-2011, 03:28 PM   #32
rjSupra
rjSupra's Avatar
rjSupra is on a distinguished road
Default now resistance figure are correct all way to AT from ECT - go figure
this a.m. i reconnected B connector from ECT to AT, that's all I did.
I re- Ohm tested the 3 solenoids and guess what?
They are all metering in at around 11 ohms - in spec, where it was supposed to be.
Either means I tested it wrong or read Ohm meter wrong first time (possible since new to Ohm -ing), or the connector was not good before and solid at least now.
So two previous posts earlier, ignore the bad ohm values on Solenoid #1, #2 and Lock. (the infinites and 70 / 19 ohm - not that value today).
Hello crazy.
88 Supra 7M-GTE Turbo, TEMS, Targa stock
rjSupra is offline   Reply With Quote
